英语动词大全1500个(英语动词大全)
大家好,我是小典,我来为大家解答以上问题。英语动词大全1500个,英语动词大全很多人还不知道,现在让我们一起来看看吧!
1. 以break为中心的词组
break away from 脱离,逃离
break down 破坏,粉碎;瓦解;出故障,抛锚
break in 闯进,打断;使顺服
break into 闯入;强行进入;突然开始
break out 爆发,发生;准备使用;起锚
break the law 违反法律
break the record 破记录
break one’s promise 失言
break up 开垦,破碎;解散,分开,分解
2. 以catch为中心的词组
be caught doing 被发现做某事
be caught in the rain 淋雨
catch a bus/train 赶汽车/火车
catch a cold 伤风,感冒
catch one’s word 听懂某人的话
catch sight of 发现,瞥见
catch up with 赶上,追及,追上
3. 以come为中心的词组
come across 偶尔发现,想起;越过;偿付
come along 一道来,陪伴;进步,进展;出现
come at 达到,求得,得到;扑向,袭击
come back 回来;恢复,复原
come down 倒下;降落;跌落;病倒
come from 来自,起源于,从~~产生,生于
come in 进来,进入;流行起来;获名次
come into being 发生,产生,出现,形成
come into power 开始执政,当权,当选
come into use 开始使用,获得应用
come on 上演;开始;赶快;发展;登台;(问题)被提出
come out 出来,传出;出版;结果是;褪色;(秘密)泄露
come to 苏醒,复原;共计;达到;归结于
come to an end 终止,结束
come to know 开始了解到
come true 实现,成为现实;证实
come up 走近;上楼;长出,发芽
4. 以do为中心的词组
be done in 精疲力竭
be done with 完全结束
do a good deed 做一件好事
do away with 去掉,废除;弄死;浪费
do good to (=do sb. good) 有益于
do harm to (=do sb. good) 有害于
do its work 有效,有作用
do much 极有用
do wrong to 做错
do one’s best 尽某人最大努力
do one’s homework 做作业
do one’s utmost 尽力而为
do proud 足以使~~骄傲
do sb. justice 公平对待某人
do some cleaning (V+ing,etc.) 搞卫生
do sb. a favor 帮助某人
do well in 学得不错,干得漂亮
do with 和~~相处,忍受,处理
do without 不需要,不用
do wonders 创造奇迹
have much to do with 和~~很有关系
have nothing to do with 与~~无关
have something to do with 和~~有关
in doing so=in so doing 这时,在这种情况下
That will do. 行了;够了
5. 以get为中心的词组
get about 徘徊,走动,旅行;流传
get above oneself 自视高傲
get accustomed to 习惯于,对~~习以为常
get across 度过,通过,横过;说服,使理解
get ahead of 胜过,超过
get along 前进,进步;同意;离去
get along with 与~~相处
get at 发现,了解;掌握;攻击
get away 离开,逃脱
get back 取回,回来;报复
get behind 落后;识破
get down 咽下;写下;使沮丧,使抑郁
get down to 认真对待,静下心来
get familiar with 熟悉
get hold of 获得,取得
get home 到家
get in 进入,陷入;牵涉
get off 送走;脱下(衣服);下车;动身
get on 上车;穿上;进步,使前进;成功;相处
get upon with 进步;在~~方面获得成功
get one’s hand in 熟悉;习惯
get out of 由~~出来,从~~得出;避免;退休
get over 越过;恢复,痊愈;克服;完成
get ready for 为~~作准备
get rid of 除去,去掉;免除,摆脱
get through 到达,完成,通过;及格
get together 积聚,积累;商谈,取得一致意见
get up 起床,起立;研究,钻研;致力于;安排,组织
get used to 习惯于
have got to do 不得不,必须
6. 以give为中心的词组
be given to 沉溺于,癖好
give about 分配;传播
give and take 相互迁就
give away 赠送;牺牲;泄露;颁发
give back 归还
give cause 给予~~的理由
give ear to 侧耳倾听
give forth 发出,放出;发表
give in 屈服,让步,投降
give in to 同意,接受;向~~让步
give off 发出(烟,气味)
give oneself out to be/as 自称为
give oneself up to 专心于;向~~自首
give out 分发,公布
give place to 让位于,被~~所替代
give rise to 引起,导致;使~~发生
give sb. to understand 通知某人
give up 放弃;停止
give way to 让步,退却;屈服于
7. 以look为中心的词组
look about 四下环顾;查看
look after 照顾,看管
look around 东张西望
look at 注视,着眼于
look back 回顾
look for 寻找;期待,期望
look down on 俯视;轻视
look forward to 盼望,期待
look into 窥视;调查;浏览
look like 看起来象
look on 旁观;面向
look out 向外看;注意;当心,堤防
look over 从上面看过去;检查
look through 透过~~看去;看穿;浏览
look up to 仰望,尊敬
8. 以make为中心的词组
be made from 由~~原料制成
be made of 由~~材料制成
be made up of 由~~组成
make a fool of 愚弄,欺骗
make a mistake 弄错
make a point of doing 强调;认为~~重要;决心,坚持
make advantages/use of 使用,利用
make after 追求,追赶
make believe 假装
make certain 确信,把~~弄清楚
make contact with 接通,与~~接触,与~~联系
make for 去向,向~~前进;有利于
make friends with 和~~交友
make into 把~~制成,使~~转变为
make much of 重视;理解;赏识
make one’s mind on sth. 决定某事
make one’s own 当作自己的看待
make oneself at home 随便,别拘束
make out 填写;开支票;理解;辨认
make the best of 尽量利用;极为重视
make up 弥补,修理;赔偿,补偿;起草;编造;化装
make up to 接近,巴结;向~~求爱
make way for 为~~让路,让路于
on the make 急求成功;增加
9. 以put为中心的词组
put aside 把~~放在一边;搁置;排除
put away 把~~放好,把~~收拾;储藏;吃喝,吃掉
put back 把~~放回原处;驳回
put down 放下;镇压;制止;记下;削减;降落
put forward 提出;拨快;建议,推荐;提倡,倡议
put ~~ into 把~~放入;插入;翻译成
put off 推迟,延期;消除;推脱,推辞
put on 上演;穿上,带上
put one’s heart into 全神贯注,专心致志
put up 举起,挂起;提名,推荐;陈列
put up with 忍受,容忍
10. 以take为中心的词组
be taken aback 吃惊
take a seat 就坐
take a shower 淋浴,洗澡
take aim 瞄准,设立目标
take away 拿走,减去;夺去
take ~~ by surprise 出奇制胜
take care of 当心,注意;照顾;提防;谨慎;处理,对付;负责
take ~~ for 把~~当作
take off 脱去,除去;离开;起飞;模仿;起程;致死;复制,作副本;减弱
take office 就职,上任
take one’s place 就坐,入坐
take one’s temperature 量体温
take part in 参与,参加
take place = happen 发生,举行
take the place of 代替
take pride in 以~~为荣,对~~骄傲
take sb. by the arm 拉某人的胳膊
take it easy 别着急,慢慢来
11. 以turn为中心的词组
give a new turn to 对~~予以新的看法
in one’s turn 轮到某人做某事
out of turn 不按次序的,不合适宜的
take one’s turn to do 轮到做
turn a blind eye to 对~~视而不见
turn against 背叛,采取敌对态度
turn back 折回,往回走
turn down 折叠,翻下,驳回,拒绝考虑
turn into 走进;变成,变为
turn to ~~for help 求助于
turn off 关上(自来水,电器开关);解雇,辞退;避开(问题);制造;生产
turn on 打开(自来水,电器开关);反对;依靠,依赖,取决于
turn one’s attention to 把注意力转向
turn out 培养;证明是;制成;实际情况是
turn out to be 原来是,证明是,结果是
turn over a new leaf 翻开新的一页,重新开始,改过自新
turn (a)round 旋转,转过身来;改变意见;采取新政策
turn to 变成;着手于
turn upside down 颠倒过来,翻过来;使陷入混乱
